[WANTED] Steering Coupler Spring Pieces
mopowers
West Sacramento, CA
I'm in need the two spring pieces used in a 66 A-body steering coupler (see pieces circled below).
I could also use one of the earlier-style springs with the shorter middle hump (the left one pictured below)
Please PM me if you have either one of these that you'd be willing to part with. Thank you!
I do not know for sure but the 90s dodge trucks used a similar coupler try the dealer , there is also an aftermarket shaft to replace the shaft ? On those trucks. Good luck on the hunt .
