It may just be come a word in the dictionary just like ain't ain't a word and i aint supposed to say it.
Exactly. lol
My pleasure. I had a great time!!
Thank you vary much. Just got threw reading. make a lot more sence now.A good read on YB with some intelligent people contributing.
Facts About Inverse Radius Roller Profiles
Any one want to take a stab at this one?Ok next question.
Why do you have to block off the lube to a mechanical roller lifter. They have to make mechanical lifter that feed oil up thru the push rod tube to feed mag/chev tip rocker arm.
So why is this tubing or sleeving required on a mechanical Roller lifter. and for that matter why is it not required for mechanical Flat Tappet lifter?
Bushing the lifter bores negates the chance you will expose the oil band on the lifter and lose oil pressure. Plus bushes correct lifter bore locations and fix worn out bores that leak oil and kill oil pressure.Because Mopar blocks are a crap shoot. The chamfer on the lifter bores and inconsistent placement of the bottom of the lifter bores to the cam tunnel, plus the big lift from a mechanical roller means that they can uncover the oil band either when closed or at max lift and the loss of pressure will kill the mains/rod bearings.
It's still possible to drill a smaller hole in the tubes to feed the lifters and pushrods, and having a smaller hole will limit loss of pressure if the lifter travels too high or low in the bores.
At least that's what I've read and been told.
Personally, for the cost of roller lifters and cams, I'd want a roller block for a roller build. Even just adding the head oiling hole to a Magnum block would give a better platform for a roller build, I think.
But is an expense that many seem to try and avoid. I'd trust bushes more, but a roller block also has taller lifter bores to begin with.
As usual, it's all combo dependent and there's no way to tell if it's all going to work together until it's been assembled.
Not every shop has the fixture needed to do Mopar bushes and it's about $900.00 to buy the tooling from BHJ IIRC. And maybe $500-600 to do the work plus parts (but the bushes are pretty cheap).
YR I grasp the importance and the mission of "tubing the block". What I am not clear on is where this plumbing physically is taped into the block. Got some pic's or a link?If you are running a SFT or a relatively small roller cam you can get away without bushing the lifter bores. I've run an X block 8500-8800 without bushings.
As mentioned above, the tube in the passenger side gallery should be used any time you are using a solid lifter. I'd say at this point, you should be tubing the block and restricting oil to the drivers side even with hydraulic lifters. You just drill an .0625 hole in the tube where it breaks through the lifter bore.
Even with a brand new block, the leaks at the lifters are incredible. Take a used block, or end up with some .0010-.0015 small lifters and you have a massive set of internal leaks. The tube fixes that. And that's what counts for most guys. Getting control of the oil, where it goes and eliminating huge oil leaks.
If you are going to build a serious effort engine, you should bush the lifter bores because you are also correcting the bore axes while you are doing it.
Not a fan of hyd roller lifter. Why are you choosing to run a roller cam? To snap the valve open to a usable lift faster. Which requires stout valve springs/valve train. Which are the enemy of a hyd lifter. Also they can allow the wheel to bounce which will kill the lifter quickly.
Who is the manufacture of the Hydraulic roller lifter that you are currently running?Ok let's clear up a couple of things
I'm not thinking of going to a Hyd roller, i am running a HYD roller.
Yes when i first started the motor the lifters were nois-e-R then i would have liked but smooth out after my first stomp with them.
I shift a 5800-6000 so HYD are within their limits
But i have ran then to 6800 rpm in a 1/4 mile just to get to the finish line. no power there but they held up.
After i went with the Hyd Roller......I kinda wish, that i had went mechanical roller, but they just seamed to complicated.
bushing the lifters is a great idea but i would never do it so i can turn 8000 rpm.....because, i can't see building a top end that could hole up to that.
Ironically my bottom end was balance to go 7500.............
YR correct me if I am wrong here. Aside from the large chamfer and oil band issue, a high lift roller cam coupled with an overly large oil hole in the bore can cause a leak also. My understanding is the relief cut in the lifter body for the roller may uncover the hole. Seems a guy would need lots of lift but blocks do vary.
I just had Mike Jones spec me a cam and lifter package for my 422. I asked for a SFT and when I mentioned that my block was tubed he said he would not recommend using a SFT because splash oiling was not reliable enough.As mentioned above, the tube in the passenger side gallery should be used any time you are using a solid lifter.
I was under the impression that if you "tubed a block" that you were adding lubrication to lifters.I just had Mike Jones spec me a cam and lifter package for my 422. I asked for a SFT and when I mentioned that my block was tubed he said he would not recommend using a SFT because splash oiling was not reliable enough.
