Hello, before I attempt to cut out this non-A/C plastic bezel to use for a factory A/C control install, I thought I’d ask members first. It looks like it would work. Just don’t want to mess up a good bezel. Thanks to all
I have a factory ac wood grain Bezel if you are interestedHello, before I attempt to cut out this non-A/C plastic bezel to use for a factory A/C control install, I thought I’d ask members first. It looks like it would work. Just don’t want to mess up a good bezel. Thanks to all
I did the same thing on my rally dash, but it was all flat. I actually cut out a lot larger area glued it in and then bought wood grain decals from Detroit Muscle to cover up the splice. Can’t tell it is spliced at all. Yours with the inset looks a lot harder.
