[FOR SALE] 1974 dart 4 door parts
I'm looking for the three groove crank pulley and the 3 groove pulley for the water pump To run the A/C belts Also looking for the A/C compressor brackets Thanks
I have a 3 groove pulley and some of the small ac brackets and maybe the water pump pulley,but not the main bracket that bolts to the top of the water pump and compressor.
I'll take the gauge cluster, complete as pictured with gauges, switches, circuit board, etc. I will PM you with a list of some other parts you may have, when I figure out how to do PMs.
sold the cluster and pmsd you on the other stuff
Do you have the front light harness, front and sidr turn signal globe holders.
And also all the rear light globe holders?
I'm looking for the K member. I understand yours is a V8 from a '74. Let me know if you still have.
Thanks.
Do you still have the radiator shroud? If so, is it for 22" or 26" radiator?
Tks.
