So, After researching this a bit I found about 5 different answers on how much of a change going to Dr Diffs 10.95 would make on my drum equipped 1971 Dart Swinger. I've seen everything from no change, up to 1-1/8" . To put this to bed once and for all I measured. I set each assembly up on my mill table and used a height pointer to the CL of the lower ball joint zerk fitting. The final answer is …. the disk conversion shifts the wheel mounting surface out by 23/32" or .656 on each side. Pics on my setup below.
Hope this helps someone out.
Regards,
Steve
Regards,
Steve
