barracudajohn
Removed from a barracuda that sat outside for years, it was covered by the hood and still has oil in it, but it is locked up from sitting. Very rusty as you can see from the photos. Plug wire separators have become unglued from age, distributor has been converted to electronic ignition, I believe that the carb is incorrect for this and is rusted from sitting. Air cleaner had holes drilled in it at one time and has a rust hole in it. The bell housing, clutch, and flywheel are NOT included. Has alternator, starter. Selling as is. No idea if this was in running condition when it was parked. Must be picked up. Located in ZIP 18038. 450.00
