[Found!] Mopar Stage VI Big Block Rocker Arms
PROSTOCKTOM
West Central Indiana
Looking for at least the intake rocker arms for Stage VI heads. They are .450"-.465" offset on the intakes .The ones MP sold were part # P4876438 for the 1.5 ratio. Would be interested other options as well.
Thanks,
Tom
Thanks,
Tom
Probably more than you're looking to spend, but I've got a pair of the Chapman Stage VI's that I had Mike at B3 go through. He has a custom part number proprietary to him for the Stage VI's with TD. They're not cheap, but have all the geometry corrections that Mike is known for built in.
Here's the TD's
Mine are P4876383. I believe the Chapman heads were a different casting than the standard.
I am not using Stage 6 heads. Have the short side wall flat and the backside filled on a set of 452 heads. Need the Stage 6 rockers so I can move the pushrod over.
Tom
Tom
Looked at hughs rockers yet ?? Look a lot like my hughs rockers on my raised port heads , except for the oil trough.
Good luck. I have a new set of P5249579 Max Wedge ported heads that I’ve been looking for the same rockers.
