[SOLD] 340 short block rebuilt its -1 block
moparraceman
mansfield ohio
i have for sale 1971 340 rebuilt short block -1 block very hard to find its been cleaned ,new cam bearing ,brass freeze plugs. its been decked 010 for flatness.030 new bore , new pistons 10.5-1 , line honed ,new forged steel crank , new rods, new ARP bolts on rods and main caps.new hyd cam ,no lifters. new timing gears and chain , new alum front timing cover price $2500 pick up mansfield ohio
casting date are in photos , 1971 block ,got a new pan but its wrong one no paper work om engine. the guy that had it built died got the info from his son only have what you see in photos
ok thanks but iam not selling it for the year, it is a -1 block which is very hard to find, iam selling it for what it is in the way of parts and assembly
i have had alot of 340 blocks the best i have had is a #5 the engine builder told me on a scale of 1 to 10 10 being worst one to build and 1 to be the best. i dont know what all that intails the engine builder has one block -1 he said they bring $600 to $800 bare block ?
Correct. Just ask oldmanmopar. Kim
where is the stampings on the flat machined area on pass. side? where is this -1 value info-it is not the 1st casting out of a new mold-these are sand castings-not permanent mold. the dozens of blocks poured every day use the same wooden pattern to make a sand mold for every block.
