Slantsix64
So my car has the original carpet which is brown, and the headliner is gold-ish. for the carpet i dont see a brown option, and the head liner im guessing would be sandalwood?
there like light gold, ill post up some photo right nowIs that pearl white seats? And are the door panels white? I’m betting it was a black or gold carpet when new.
Yea It certainly does may be dark saddle
Thanks for the info that ACC site is a great help i believe it is sandalwood for the head liner and brown for the carpetIf you should look at the ACC chart, they show under the factory colors a Medium Saddle-11 or Gold-20 that would have been the equivalent of the factory colors. You can also look at the ACC site and select "Show All Colors" for a wide variety of colors that you feel is more correct. On the custom colors, those colors are non-returnable if you should decide to use a "custom" color. You might want to look under the seat or console to see if you can find a better color of the material that has not been impacted by the 50 plus years of sunshine and use. ACC is also good about supplying you with small pieces of material so that you can match them up with your originals.
