Need help identifying these pieces
j_anderson
Fort Wayne, Indiana
Hey forum. I am in the middle of a resto on my '72 dart. I am looking for help identifying what the rubber seals/plugs are called that seal the door hinge bolts? I believe there are square rubber pieces and round rubber pieces needed to seal the various hinge bolts.
Looking for replacements. I have uploaded an image of what I am looking for. Any help you can offer is much appreciate. Thanks in advance
It's actually seam sealer that was applied just before the hinges were bolted down tight so it 'squished' into the square holes.
It's available in a tube from Eastwood - Eastwood Seam Sealer Cartridge
Make sure you have time to adjust each door exactly where you want it before using. Once it dries it makes the doors hard to adjust.
