Bronze Barracuda
Ok i thought I was trying to piece together a 10.95 inch small bolt pattern brake setup. But I think I made a wrong turn.
I do not want 4 piston calipers.
I have 73 upper control arms.
Whatever I can buy from Rockauto I will.
So I obviously need spindles, caliper brackets, and dust shield, from either Dr. Diff or privately.
But it seems the only way I can go with the small bolt pattern is to use the 4 piston setup? Which doesn't work with the 73 & up upper control arms. (I think). Also it looks like the rotor assembly is different with the SBP. The hub is seperate from the rotor. So I need to go with the 11.75 in rotor hub assembly which is big bolt pattern. Which means I would need wheels with the big bolt pattern. Or is it possible to buy a hub rotor assembly that fits into the 73 and up spindles. I know I am probably missing some info. Also will be running a sway bar in the future. Car is a 68 barracuda.
