Mullen cyl heads
SS Lancer
North Carolina
Greetings - could anyone tell me if the Mullen oem 360 castings run TA 340 shafts and rockers or reg W2 shafts and rockers ?
Also will the Crane/Mopar blue .775 offset rockers work with these heads
Thank ya
Thank ya
Very much !!!
I'm pretty sure they ran the W2 rocker arm assemblies. If you look below the "3304" number, you will see the unbored pad for normal LA rocker assemblies.
The casting number matches a 1975 to 1976 360 casting number. But machined differently.
That is at least the T/A offset. BTW, I have a set of brand new MP T/A rocker shafts. If you need them, PM me.
So u think reg W2 rocker arms can be used ? Im going to add a photo from previous owner where Norris rockers were on head to show me set up etc.
New guides and seats installed
Trick Flow valves (5.200 ) length and all other hardware on the way !
