I agree with you the best 60 ft the car has ever done is a 1.52 but it has gone away over the last year or so maybe the converter I’m currently running? 8 inch tci stock leaf springs with caltracs 12:1 compression with edlebrock performer rpm heads and the cam is 270/280 620/625 solid roller on a 108 I believe it’s to much cam for a foot brake since the rpm range is from 4500-7300 but hopefully it may work better with a trans brake leaving at about 4600-4700 running 4.10 gears currently but will put 4.56 in i when the glide goes in the car
If the convertor is well matched to the combo it should 60 foot the same,or awfully darn close either way.
I have posted this before. Had a high 9’s Smallblock stroker. I raced it 7 or 8 times a year in a points series that had a .400 pro tree 10 flat index race, and on those same nights, a footbrake bracket race.
Car went 1.35-1.36 either way i launched it, off foot, or at different Chip settings off the brake. Same exact ET either way, wheels up, or not so much in the air off the foot.
I will go a step further and say, regards footbraking, in any car i have ever had, whether i leave off idle, 1500, 2000, or as much as i can physically load it up and not have it creep, the 60 foot doesnt vary. Its still immediately headed to the flashpoint, like side stepping a clutch, before it accelerates from there
The reaction time will, of course change,but not the 60 foot.Further from the flash you footbrake it from, slower your reaction time will be, compared to leaving closer to the flash... not a ton... but some... useful in getting dialed in to the tree
Those results are having used super stock springs and ladder bars in different combos.
what does your convertor flash at? That does seem a huge cam. What gear?
edit... 3500 TCI convertor... from the sounds of it, likely you have a super street fighter type 10 incher. If so, that is 99% likely your problem.
A ten inch 3500 convertor and 270@ 50 cam equals... not good
