AR Engineering low mount alt. kit 443 compatibility with the 238 head mount coil bracket.
bb70swinger
Member
new provinece pa
I'm putting the final touches on my 440 and was thinking of running the msd hvc2 coil. I have the ar engineering low mount alt. kit already and was wondering if anyone knew if the spacer for the alt. would clear the coil? I know I'll have to machine down the spacer the thickness of the coil bracket. By the way great stuff. Check them out if you haven't yet. Thanks
Had to build my own , sits where the orig. fuel pump would have been .--motor plate.
