What mounts are these
zigs
Yakima, Washington
Abody 318 / 340 ?
two on the left look like a 318 left and right.
The curved one (upper left) is the DS.
The 340 piece would be visibly narrower.
Other two look like B or E or big block isolators.
They are 318 e-body or b-body Brackets and rubber mounts. I have some for 340's . Like someone stated the 340's are narrower on the left side.
So to be clear the ones I have showing will not fit my 72 340 unless I modiy them
The passenger side will, the drivers side will need modification.
The rubber biscuits won’t fit an A body.
Hope your not getting your guts baked out over there. It’s freaking HOT!! over here. Take care of yourself in this infernal heat!!
I got those mounts with that Duster. Thought it would be nice to use them on the 340. If I just have to narrow DS , no biggy.
Ya second week of 100+. Yesterday and today a little cooler. Im going to be gone next week to Bend Oregon ,when I get back Ill call you ,I have everything for the build. Put the Duster up for sale Thurs. I could have sold the hood about ten times.
Nope... the bolt hole orientation for the biscuit mount is in the wrong position. I guess you could drill new ones for A body location.
They are 318 brackets as well.
