[FOR SALE] Autometer 6 gauge set like new 350.00 shipped
northeastmopar
Massachusetts
This is a 6pcs set I had in my 72 Demon. I bought these brand new and have since opted for something with GPS so this is for sale. These are almost new. The speedo was never hooked to the tranny and I have the adapter that goes on the tranny. All other gauges were operating fine. The fuel gauge was a little wacky due to an aftermarket sending unit but it worked. The fuel gauge also has a slightly different light as I wanted it to stand out in the car. I paid about 600 for this setup and will ship it to you for 350.00.
Are these mechanical or electric?
speedo has a sending unit which screws on the tranny and sends a signal thru wires to the gauge. water sends a signal thru a wire from the temp sending unit in the manifold. Oil the same as water. Volts wires to the sytem. Tach wires to the msd or coil and sends a signal thru a wire. Fuel sends a signal from the sending unit in the tank to the gauge. Hope this helps.
