Vinyl top trim fasteners - looking for source
str12-340
Vashon, WA
The car is a 1970 Dodge Dart. This is NOT about the readily available trim clips that bolt on at the bottom of the back window!!! On my C pillar the trim is secured by odd screws that the trim clips directly over the head.
Below are some pics of the old rusted screws that came out. Again, there is no molding clip attached to these screws, the vinyl top trim just clips right over the head of the screw. Anybody who knows where to find/look for these, I would appreciate you responding on the thread. I've been looking for months! If anybody even knew what the name for a screw head like this would be, that would help. The head is exactly 5/16 of an inch wide at the widest part.
Thanks for any help!!!!
I found similar ones on eBay but threads did not continue up to the head. I also need them for a Barracuda. Mine had a little plastic spacer/washer. Let us know what you find.
I had luck calling Restoration Specialties about some clips that were not in their catalog, they had the exact correct clip.
you need to call these places and not rely solely on website catalogs.
Alan
I found similar ones on eBay but threads did continue up to the head. I also need them for a Barracuda. Mine had a little plastic spacer/washer. Let us know what you find.
That's them!!! and yes about half the ones I removed had thin clear plastic washers on them, which promptly fell apart. I think they keep the trim itself from damaging paint/vinyl when installed.
Sorry, I missed the ‘not’ in my statement. I’ll keep looking, too, and will let you know.
Can you give me a link to the ones that you found? I have a friend who is a machinist and we can see if we can set something up to thread it all the way up. If it works I'll let you know and make a bunch.
This a screenshot of what the seller dith612 has on eBay. You can see the threads stop. Someone else on here found these in another thread. No mention of head size but looks the part.
This a screenshot of what the seller dith612 has on eBay. You can see the threads stop. Someone else on here found these in another thread. No mention of head size but looks the part. View attachment 1715634943
These are designed to hold a clip and not the trim directly, if you look at the original posters screws they have a chamfered head and are a different diameter. I tried these and they do not work.
Alan
So, you were the one who found these. Yes I see the chamfered head on our used screws. We will keep looking.
I sent the original post, and these don't work (I think they are a work around on a car that has little posts with heads if you lose a post, you can use these to hold the clip that originally went on the post). The heads are WAY too small
I sent an e-mail to Tom Race at RT Specialties to see if he has a source or could locate one.
Restoration Specialties got back to me in a couple days on some other clips I was looking for.
Alan
View attachment 1715633296 View attachment 1715633297 View attachment 1715633298
Hello I’m looking for the same type of screws 3 on Each side I Only have one do you found some for your past project or what do you use instead .
Thanks you
I ended up using the same clips that are used on the rest of the vinyl top trim. They work fine but are a pain to install (getting the nut on the back). I think Chrysler used those odd screws because it would be too expensive to have a factory line worker crawl into the trunk and snake their arm up above the wheel well to do this, but for us it's all in a day's work!
Im.inndire need of these asap and can't find them anywhere. I have an appointment coming up to have my new vinyl top installed
I used the same clips on posts with a pal nut that were used on the rest of the top back there. It's a pain getting to the backs to get a nut on the post - definitely easier with some else helping to hold the trim in place, but I think the only reason they used those odd screws is that they didn't want to take the time on the line to get someone in the trunk and someone outside to install the clips.
Don't know what you are working on. I have a 1970 Dart. I just reached up to the back of those locations over the rear wheel well in the trunk. There are actually openings in the bracing that allow you to get to the ones farthest back in. The farthest one are accessed lying in the trunk. Be sure to look around with a Big Flashlight for the best access for each nut. I just took these pictures for you:
The white stuff is from the paint shop when they buffed out the paint with the trim removed. Rubber ring on the post clips seals the holes nicely. Good Luck
