From our Cohort @318willrun
I took a chance on SM's crank trigger setup yesterday for $125. Didn't know they sold them until it showed up in a Summit search. Wheel/brackets look like copies of the MSD that was selling for $310. I was likely going to modify the MSD version as it was, at worst i can imagine maybe replacing SM's magnets and pickup.
Grant
The bare heads are each. Look towards the bottom of the page and it will tell the quantity.Are these prices for 1 head or a pair of heads ? I am looking at the cnc pair bare ?
Long before I bought my Speedmaster heads I checked into all this doubt casting on these heads... Everybody who ran them out of the box seem to have good results.. when I got mine I took them down to a machine shop and they took them apart put them back together.I really wonder if you’re playing with fire running these fully built heads right out of the box. And I’m sure they’re work, but for how long? I guess for a budget build, sure send it. But if you got money in your bottom end, I’d be afraid to bolt on cheap heads and run them hard, but that’s just me. You gotta ask yourself, do you feel lucky, well do ya? . Bare castings built up with quality hardware sounds like the way to go with these.
After seeing the SM beside the Edelbrocks, I don't think there any way I'd have Eddie heads.^^^as a matter of fact I'm even hearing the gurus saying they like them better than the Edelbrocks...
Hello,trying to figure out if these are closed chambers or open.I prefer closed chambers but there site doesn't say.After seeing the SM beside the Edelbrocks, I don't think there any way I'd have Eddie heads.
@MOPAROFFICIAL Has a positive opinion of these heads.
Here's the link to the site... Now if I could just get my rich uncle to quit squeezing that pile of Franklins and Grants so hard...
Engines & Components > Cylinder Heads > Cylinder Heads
Closed ,cnc 68, std 65Hello,trying to figure out if these are closed chambers or open.I prefer closed chambers but there site doesn't say.
Has anyone put a 2.08 valve in there 190 heads and have results?
If I have a BB 383 street car and looking to reduce weight on from end, Do either of the cast BB heads strike you as better? There is a 23$ difference. The runner and cc are the same.
edit...I see it now. Hydraulic roller vs Hydraulic flat tappet.
Or use oil through the pushrod rockers.On the Magnum to LA head, Either have a machine shop drill the oil holes for the head or partially drill and intersect the holes and drill and tap tap to pressurized oil feed in the galley to run hard line. Or find a 360 LA core and start over.
One says for hyd flat other hyd roller what’s the difference the spring set up or the push rod holes?Or use oil through the pushrod rockers.
Which roller rockers are better the PCE or the Speedmasters? PCE shows in stock. Ready to pull trigger but wanted testimonies on them
Probably pushrod tube and springs.One says for hyd flat other hyd roller what’s the difference the spring set up or the push rod holes?
How good are the SB intakes? Do they have bad coreshift issues like the older offshore intakes?
Do they make a BB intake?
