building 496 low deck
gpc213
Active Member
shepherd,mi
getting rotating back this week full balance went to this cu in son bought the wiseco pistons for me had trouble finding 400 block that was not too worn to go to the bore had one but needed the bigger bore found one out of estate car going in 69 dart my oldest son bought about 20 years ago had in the barn since hasn't been on the road since it is an out of state body he was going to sell it so i bought it 12 years ago going to be mainly play car it will be his after i am done playing my younger son has a 91 z 28 witch ls balanced cnc ported heads, headers,850 demon carb, 8 pt cage 9" rear 6 speed duel clutch this car came from ill build for street racing need to show him how the old mopars run !!
Already have solid roller lunati cam 585 lift, gear drive, fitech injection, duel valve springs, 2 different intakes torker 2 and a duel plane db452 need thoughts on heads this is being build on as mid budget build ha ha
this is a 496 cu in low deck
Look hard at Trickflow heads!
