[WANTED] Lower control arm STUDs
j061093409
1970 Dart Swinger 340 Reg
Wethersfield, CT
1970-2 original studs in good shape. Must look like unit in photos. Needed in CT.
FYI
Those pivot pins, "shafts" studs, are all the same on the A body line of cars from 1962-76.
If you can't find a good used pair, they are available new, for around a hundred bucks a pair these days.
Nigel and National Moparts has 4 x NOS ones C/W bushings installed available. $59.95 CDN each
I have NOS shaft in box but is different shape as box is dated 1978.
This has a different shape
