833 manual to 904 automatic questions
Ryanj397
New Member
Washington
So I’m in the process of swapping the original slant 6 and 833 out of my 1975 Plymouth Scamp and am swapping in a 1977 Slant 6 Super 6 with a 904 from a dodge aspen and am planning to put in a floor shifter with it. Is there anything specific that I need to change on my car doing this?
Sorry if this has been asked before.
Is that really all there is to it? Lol way more simple then I was thinking it was going to be.
Don't quit thinking. you'll need the correct kick down linkage . If the Aspen still has it on there , better get it also. Maybe the drive shaft too. Not sure if they would be the same.
Trans cross member and mount might be different to.
I have the linkage all setup. I noticed that there is a electrical plug that comes off the side of the transmission on it though and I’m not sure what it’s for exactly....
until you start putting it together and figure out what parts your missing or things your not sure how to handle, kind of hard to say what all you need to know :thumbsup:
neutral safety / reverse light switch. do you have the factory service manual for your car? get one if not. i don't see 75' but 73' will be pretty close for this
good luck
