Help with Parts ID throttle pivot bracket, Z-bar, and automatic pivot shaft
413
NW USA
I Could use help with some parts ID. Let me know if you recognize these parts. Please don’t guess at it, it doesn’t really help anything.
1) Z bar torque shaft. Nothing written on it, tube is 7 13/16” long, one lever has a half round notch in it. The bracket has 3 threaded holes in it. I have 2 of these. Brewers site doesn’t have this one, so I know what’s it isn’t.
2) looks like an auto trans column shift pivot bar, it has the brackets on the end. One for frame rail and one for trans ear. Has 66 Dart written on it. Is that correct, any way to know if V8 or slant 6 Or are they both the same?
3) looks like a throttle pivot Bracket and rod. Is it for a 66 dart like part #2? Has 2 bolt holes for mounting. I have 3 of them. Thanks for your help.
any idea on value? All are for sale.
I Could use help with some parts ID. Let me know if you know these parts. Please don’t guess at it, it doesn’t really help anything.
1) Z bar torque shaft. Nothing written on it, tube is 7 13/16” long, one lever has a notch in it. The bracket has 3 threaded holes in it. I have 2 of these.
2) looks like an auto trans pivot bar, it has the brackets on the end. One for frame rail and one for trans ear. Has 66 Dart written on it. Is that correct, any way to know if V8 or slant 6 Or are they both the same?
3) looks like a throttle pivot Bracket and rod. Is it for a. 66 dart like part #2? I have 3 of them. Thanks for your help.
Those all are early a 64-66. First is 273 3/4 speed Z bar from what i can tell. The one marked DART is 65/66 column shift. The last picture is for 2 barrel throttle kickdown and mounts to the back or the cylinder head.
Jake
Another piece to ID. Does this go with the back of cylinder head part 273 2bbl?
looks like Kickdown linkage, or auto throttle pressure linkage. Looks like lower rod to trans and the vertical rod up the firewall. look at the odd pivot piece. I have one. All of these are for sale, any idea on value?
That connects to the bracket that bolts to the back of the head for the 2 barrel throttle.
Jake
Last 3 pics is for the kick down. 65/66 V8. The swivel goes on a stud on the tranny. Kim
Any ideas on value? I don’t need these parts. Thanks for the help it just looks so strangely odd. I’m a b body guy mostly. Different stuff.
I would say 20-40 bucks. The only reason I know is because I wrecked a 65 valiant with a 273 auto and that piece was left on the tranny. Kim
