[WANTED] Help! Need Output Flange for B&T 4-Speed
eekvonzipper
My Member is Legendary!
Cadet, Missouri
Anyone have this Flange?
I bought the wrong one from a member here that has a 4 1/4" Diameter (Pictured Left)
The One I need is 3 3/4" Diameter (Pictured Right)
it's for a 1965 Ball and Trunnion Barracuda 4-Speed w/ the 3.09 gear.
Mine is badly pitted in the Seal area and the threads are all clapped out...
Would also Send you the larger diameter one if needed
I’ll see if I have a pic. No pic of the tranny tail shaft end. U can see that the tail shaft under the tranny mount doesn’t have the plate for the bearing retainer snap ring. Kim
