[SOLD] 1972 318
RAT ROD AL
MOPAR ARCHAEOLOGIST - one parts hoard at a time!
Robbinsville, North Carolina
Anyone have any interest in this before I take it all apart. Any or all of it. It turns by hand. Looks unmolested except for the missing rt side valve cover and rockers. Have to put a price, so $150 for the long block, or piece it out.
Date on block is 10-4-72
I'd be interested in all the bolts, fuel pump eccentric, pick-up, oil pump drive, cam thrust plate ect. if you decide to take it apart. Labled baggies if that is doable. Basically looking for the stuff to put together an engine. I have the block, heads, intake, oil pan, crank etc. PM me if you are considering stripping it down.
Care to show us the numbers on the front of the left cylinder bank below the head?
JM318R 4094 1300
J= 1973 model year
M= Mound Road Plant
318 cu. in.
R= regular fuel
4094=103 day of 1973 April 13 1973
1300= 1300 engine built that day
Tell me if it's a good un!
Yeah, it's a good solid foundation. I know of a heavily loaded 391 stroker built from a 1973 block with main and head studs and stock caps that gets the pee water run out if it on nearly a daily basis. With 11.4:1 and Edelbrock heads... that also does some towing duty. I'd classify that as a good un!
