Max rpm stock 360 magnum??
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
Stock block , heads, crank,pistons, rods
Good valve springs
Cam 498/274. 512/286
Supposed to pull to 6500
Do you rev it that high? That is a roller cam right?
Yeah I do, it has a 600 cfm carb rpm air gap intake that’s about all I added to the motor. And yes roller camshaft, all magnums have roller camshaft although the 318 magnum has a more nicer camshaft specs than the 360 magnum why I dunno.
6000, it won't be making any more power beyond that point.
This is a 380hp create engine
750 cfm M1 single plane and similar cam
Should be similar output not down too much at 6000rpm but probably fall quick after.
With the right sprAngs, it'll go 6500.
Good valve springs
The cam probably would pull to 6500 rpm but not with stock heads. displacement and heads will change where a cam works.
