[FOR SALE] Brand New MP 440 Tunnel ram with Custom Rework
GTX JOHN
Boulder City NV.
I have a Rare and Brand New Never Run
Mopar Performance Tunnel Ram
I had it tested and it flowed ONLY 300 to 305 CFM
I had Ed Vickory (Junk Yard Ed) Famous Cylinder Specialist to
Modify the Plenum and match the ports to my Edelbrock 440
Heads that flowed 352 to 358 CFM on intake side.
He modified and checked them on the flow bench until the manifold now
can flow considerably more than the Heads! I wish I could have tested
them to see if they what improvement they made on the track.
I have about $880. in this manifold with the work and never even
fired the engine with this manifold and Ed was my good Friend
and always gave me a Deal!
Mopar advertised this Manifold to be 25+ HP over any other Cast Tunnel
Ram on the market with production Heads. If your heads have some flow work
it will be a lot more than that!
I will take $425. plus the ride
I have a brand New Never Run
I had Ed Vickory (Junk Yard Ed) Famous Cylinder Specialist.
Modify the Plenum and match to ports to my E.delbrock 440
Heads that flowed 330 to 335
You can see the result on the flow bench on the manifold and now
they flow more than the Heads!
I have about $780. in these and never even fired the engine with this
manifold.
I will take $375. plus the ride
i have this same manifold ! I ran it on a 4:350 440 ! Ran really well ! I’ve still have it ! Did they build this manifold for the low block as well ? If so I wonder if anyone has one for sale !!
