What is this ???
dodgegtdart68
landfall,mn
It came off of my 1968 Dodge Dart GT somewhere. Was taken off over 10yrs ago
Reverse lamp switch. Bolts to the steering column, down by the floor on top. Column shifted cars. Until the 3 prong neutral safety switch came in 69 I believe.
EDIT: the neutral safety switch on the 68 is on the drivers side of the trans. One threaded post. The wire goes from there to the starter relay and provides a ground signal in P and N.
Reverse lamp switch. Bolts to the steering column, down by the floor on top. Column shifted cars. Until the 3 prong neurotransmitter safety switch came in 69 I believe.
It was a. Column shift GT. I moved it to the floor n was wanting to hook this n a neutral safety switch.
