[WANTED] Found: distribution block for a 9 inch drum car with dual master
Ed Ruhl
Auburn Hills Michigan
I found one! thanks all
I need some help here
I ordered a drum drum power brake kit with dual master cylinder (both reservoir's same size) and the valve I received was a proportioning valve used on drum / disk conversion that shuts off fluid flow and adjusts for disk/drum braking and doesn't work obviously.
I plan on doing this disk conversion when funds come ( and I will have the proportioning combo valve lol) however to get my 65 on the road I need a 9" drum/drum dual master cylinder distribution block. (5 port- 2 front, one rear and 2 to master cylinder).
Anyone have and want to sell such an animal?
Thanks
Ed
Thanks
Ed
I have one that I got with this kit. Let me check how many ports.
The unit on the top is for my disc brake Dart. The unit on the bottom should be what you are looking for.
Thanks
Ed
Hi I have one ,go to your p m
