Indy rockers
BVoelzke
North Jersey
I broke an Indy 1.6 rocker on my 360-1 heads ( a blue one ) its for #2 intake. I know they don't make them anymore and aren't available before I switch to another brand rocker set up for now I would just like to replace the broken one does anybody have any spare rockers laying around they would like to part with? ( I posted in parts needed also but I feel more people look here I will delete if not allowed )
I recall seeing on Indy's website that their 440-1 big block heads and 360-1 small block heads use the same rockers. This may give you addition sources with the big block crowd to find some spares made by Indy or other companies.
Thanks Rocket!!!
If you don’t find the single one your are looking for, try calling Harland Sharp. I bet they could build you a copy if you sent them one.
How did it brake? Just curious. Assuming it was running when it broke.
Hughes Engines sells a kit for the 440-1 and the 360-1 heads. They should have spare rockers for sale.
Hughes Engines
My brother switched to t&d a few years back so he probably still has his indys.I'll check on it.
I have contacted Hughes and sent an Indy rocker to them to inspect and compare to theirs .. it broke second round of eliminations last weekend when the car slowed a lot and I didnt know why until I pulled the valve covers
