[SOLD] Small Block Motor Mount Brackets
moparvinny
Macomb, MI
For sale: Pair of original Mopar small block motor mounts.
Price: $140
Are these E body small block.
I believe A-Body, but open to the forum to comment. The brackets will attach to 273/318/340/360 engines, but some may require a one inch spacer to attach to the ears on block depending on the spacing (between ears on the block).
The one on left appears to be an A body drivers side 318 , but the other one the biscuit holes are not the proper orientation.
LEFT IS 273-318 67-72 A-BODY and a spacer wont help you cause there is no ear on the mount to use on a 340-360 block
You can modify the drivers side mount to work on a 360 340 buy welding on an ear, if you are adapt at something like that, and aren’t worrying about part correctness, as the 340 360 mounts are very scarce at this time, and if you find them they are expensive.
