MoparMark91
Alright guys well I did the whole overhaul and even opted to go with a deep pan and switch out the oil pump. I cleaned up the passages on the oil pump as well and put a high pressure spring in it. Just took it for a spin and when temp is at 190-200 in gear at a light it's 25-30 now. I went with the moroso 8 quart pan as well. I think I'll see how it does and just avoid taking it out on hot days. I also switched type of oil filter as I went from a wix to a k & n gold. I'm satisfied with the results so far I'll update if any change. Thank you guys again to all your input and help
