512Stroker
We are all here because we are not all there.
Why do some lifter manufacturers offer a .903 solid lifter vs the standard .904 ?
I did not look at the hydraulic lifters, just solids.When I was researching solid roller 426 lifters, I saw some that were spec as .903 and the same place had 440's as .904. Maybe it was for clearance or tolerance or something. Weird, were the hydros .903 also?
What would it hurt to run a .903 in a .904 lifter bore? Oil pressure?Pure speculation: If you bush the lifter bores or tube the oil galley (small block), you may want to run a bit more clearance without pressurized oil at the lifter?
That would be my guess. Everything in the bottom end of an engine is nothing more than a controlled oil leak... the issue can be keeping it from becoming excessive- a little here, a little there.What would it hurt to run a .903 in a .904 lifter bore? Oil pressure?
I would think if you had a tight lifter bore that would work out.The old MP P2843177 solid lifters were listed as .0005” undersize.
They measure .9035”.
You are dead on with your info.The confusion comes in because .904 is Chrysler's lifter BORE diameter in the BLOCK, while .903 is the actual lifter diameter itself. Some vendors incorrectly list the lifter diameter as .904 and that's incorrect. Chrysler's lifter diameter in these engines is .903 and always has been.
Rusty do you have any preference standard weight vs light weight solid lifters?
Rather than get into a debate about what size the lifters are “supposed to be”........ I’ll offer a couple of pics.
One is the specs listed in the catalog from Hylift Johnson, the other is a mic measuring one of those lifters:
The lifter bore burnishing tool for a Mopar from Goodson is .9060” diameter.
If you say so.
Same deal with Ferd lifters. 0.875" bore size, 0.874" lifter diam, but you see both numbers quoted.
