Yeah and I'd like to see a j head fitted with 8mm 1.92 valves and see it's not most of why they make more ...To believe the chamber 'that varies in size from the factory' is worth that much power..eh.
Consider this
Almost every advertised chamber volume , like 99% have been misleading.
The only heads to hold true are the 302 @64cc in all of the cores I've checked.
Mags vary 3 cc and usually to the big.
In fact almost all are to the big side.
906 late castings and others can be huuuuge. The x heads I have held onto have had 5 valve jobs since I've owned them with a light mill and are still 68cc from printed 69cc...lol total bullshit. 273 heads 66cc, 318 heads 675 68cc stock, 163 and all other smog open chamber.. 72, as big as a 360. The head they sell as aftermarket are 62cc and really are...till you open the chamber for the 2.02 and bore size, cut the top angle ,chamber blend the wall side and short turn side as well the exhaust... then they hit 65-66cc... and you have to mill them near .025 to get to 60-61 cc.
That's a good idea to cast small for that alone. Sure bigger valves actually fill the chamber and eat up volume..but when it comes to a closed chamber head ..making them work for you means opening up the chamber around those valves. Open is a drop in and eat up around 3cc's instantly going from 72 to 69..then the basic mill of an old crust head.. .004 or .005 ...67.8-68 'accounting for loose factory average chamber size'.
All I know is that stock magnum isn't very dependable. These were cracked for a long time. I added water every month to the overflow tank. ..about 6 yrs. End exh seats were sunk .060.. football field seats..geometry was bad from the factory valve tips all worn .030 in from the exh side off the edge of the inside..and only got worse with wear... no valves were spinning ..burnt exhaust valves.
Oh yeah... what were we talking about again?
