Today, dollar for dollar, is the 318 faster than the 340 ???
would you agree ?
  • yep, the 318 wins if buying and building for under 3k
    Votes: 48 41.7%
  • Nope, the 340 always has and always will beat the 318
    Votes: 57 49.6%
  • Actually, never thought about it like this... Good Point !
    Votes: 10 8.7%
  • Total voters
    115
To end this debate, if I was 16 again I would go to pull and save and grab a 5.9 and see what I could do with the 3 grand.
But when I was 16 3 grand was hard to come by, it was more like a grand.
Pay attention to my new posts. I’ll say it again to save you some time. If you are going to use OE service tolerance limits there is no sense measuring anything. The FSM says most anything will run. And it will. It will just be running quite sorry. No sense measuring something when you don’t care how loose or tight it is right? Or how straight and round it is. Just keep that 1980 budget in tact.
"New posts"? You have old ones?
Have you never heard the motto in the fuel pits??? I may not get it exactly as they say it, but this is close. Measure it with a yard stick, cut it with an axe. There isn’t much precision in a fuel engine. Clearances are humongous. Pro Stock is a different horse altogether. You don’t see them slapping new bearings or pistons in at the track. They have much closer clearances and tolerances than a fuel engine does. They run water thin oil where a fuel burner uses a 70 grade oil that when up to temperature is more like fudge than oil. Two different beasts for sure.
I know it was an extreme comparison, but true nonetheless.
448Scamp said:
Same Crap.
448Scamp said:
Same Crap.
448Scamp said:
Same Crap.
448Scamp said:
Same Crap.
Moderators do not want to get involved.
That 'Short Bus" comment was so derogatory and should have been removed and a stern warning given.
Ride the Short Bus is a derogatory term for RETARDED people, To participate in a special education program, such as for those with learning disabilities riding the short yellow school bus.
What is the meaning of Internet troll?
A: A person who intentionally antagonizes others online by posting inflammatory, irrelevant, or offensive comments or other disruptive content.
318 magnum with 4bbl runs about the same as a stock 340. They are a very good engine. Even if somebody bought a 300 dollar 5.2, on a 3k budget they'd have 2700 more dollars to play with vs the 340 guys 1500. 340 guy is in a world of trouble... in my opinion.
So it appears 318willrun has given the all clear for the 318/5.2 magnum so I'm back in on the magnum 5.2. Lol
Is what I'm saying is 448Scamp still has a cobbled up scrap iron core shifted block. Type of guy that puts $7,000 into a block with core shifted and align bored. Then won't check every lobe on the camshaft to make sure it's all within spec then takes his core shifted block and gets it zero decked instead of square decked. Then does valve train geometry on one cylinder of this core shifted block. Not even realizing that the geometry might not be correct for all cylinders because of the core shift. Then gets forged pistons and runs a tight .006 on a core shifted block. That when it warms up the hot spots in the cylinders start going out of round and then his forged pistons expand and they start dragging in the bores. Then the weakened main bearing spun align bored block that has its integrity compromised and has been stressed starts vibrating around while the high pressure oil pump is putting out enough pressure that it's pushing the oil through faster than its lubricating the internals.
Don't worry I used to think like you and your machinist before. And then I learned the RIGHT WAY to build a engine. But I have been in your shoes been there done that got the t-shirt.
How do you know what I have? You have no idea. I do love that you throw core shift around like you know what it means and what to do with it.
this thread should be locked, if for no other reason than to stop 448scamp bleating on about how cheap we all are and what crap we build :BangHead:. the whole thing's gone completely off track so a waste of time now.
I never said anyone was cheap. I said you can’t build a decent engine with 3k today. And I defined what decent is and gave some prices. If you don’t like that don’t read the thread.
If you live in a glass house don’t throw stones. Troll fits you perfectly. And if you think a block is junk because it is lined honed you are riding the short bus. And the short bus is full. Does that offend you? Stop trolling.
I'm in agreement that you cannot build an engine with all machine work for 3K. Some of them don't need everything.....and I'm not talking about trying to cut corners, either. Some of them just don't need it all. It's certainly your choice to do it.
Seems like an unfair comparison if you have one engine already, but not the other. However, if one was planning a build, if both of these engines choices are present, and a person was on a budget, the vote would be to build the 318. You'd have to add in the cost of the 340 to the build before adding in the cost of building the 340
my son is special needs,..yup this chit offends people,...just another arse hole that piss's me offt! just stick to engine building....
Jesus Chrysler! This just shows you're digging. If you really gave a **** you wouldn't even say "Retarded". It's "Special Needs" for those who actually care.
At this point, with the trolling definition you posted, the only people still commenting in this thread are tolls, LOL.
Right from the beginning with the second question on the survey it was a troll thread!
