Duster /Dart doors 1970 to 1976
FEATHERDUSTER76
The Feather Duster is Mopar's Light Weight
YAKIMA WA.
What I know about My 76 Featherduster is limited to what I have learned working on makeing it better than it was when I bought it and 1 of the doors is wrecked . What I'd like to know is are the doors the same no matter if its a 70 or a 76 or if its a Dart
Duster doors are different than Dart doors. You need a door from a '73 and newer Duster. The upper part of the inside, and the inside handle are different than on the earlier ones. Good luck with your build.
I guess you'll have to do some research because my experience is a little different.
Duster & Dart Sport doors are the same in the same years, including windows. I believe Dart Swinger doors may be the same, but the window is shaped differently.
1973 has unique window mounting configuration. You should find 1974 - 1976 doors. Window mounting configuration should be the same.
@FEATHERDUSTER76 My mistake........Every time I hear "Dart" I think of Swinger, not Sport. Sorry for the confusion.
