Kody meile
hello everyone, i rebuilt a 318 la back in may , all new bearings and rings, cam, etc, it never gets past 25psi at 4k-5krpms, less than 10 at idle , its got a brand new oil pick up, ive changed the pump 3 times, the 3rd one i put a mopar performance spring in it, i run valvoline vr1 20-50
its always read 50psi with a drill when priming and im assuming 700 rpms with restistance when pump gets oil, ive tried 2 different guages, ive tried both guages on my 75 d100 ( also a 318 la) and both read 50 psi
any advice will be appreciated thank you
