73duster47
I have various small block accessories and gaskets for sale.
Part numbers, descriptions and prices listed below.
All prices are plus shipping from Fontana, CA (92336)
Carter M60514 Small Block Fuel Pump (used for 100 miles) - $10
A1 Cardone Remanufactured Saginaw Style Power Steering Pump (never used) - $30
Fel-pro OS 6566 C-3 Small Block Oil Pan Gasket Set - $15
Fel-pro 017-4340-0 Small Block Water Pump Gasket - $2
Fel-pro 521 SD Small Block Cylinder Head Gaskets - $50 for the pair
Fel-pro 1413 Small Block Exhaust Manifold Gaskets - $15
Fel-pro 1807 Small Block Oil Pan Gasket Set - $15
Mopar 1-P4452089 Small Block Valve Cover Gaskets - $12
Edelbrock 9266 Carb Heat Spacer Kit - $15
Fel-pro TOS 18583 A-727 Transmission Pan Gasket - $5
