71 Duster rear seat belt positions
Uncle Bob
Shiny paint causes stress.
Almost Heaven, WVa
My 71 Duster did not have rear seat belts when I got it. Now I've got a set and was wondering which belt half goes in which position? There are 6 separate belts making the set of 3, and they are not sewn together like the factory belts.
There are four mounting points for the rear seat belts, so if you have 3 sets the center set of belts would share the center two bolts with the right and left side sets.
I put them in so the L and R positions match the fronts with the female ends mounted to the outside, and then put the center position in with the male end on the driver's side.
