Replacement 68 340 four speed cams
I would be interested in the blueprinted 340 manual cam. I used these in a lot of customers cars and never had one complaint. I used them in my street motors and loved them. I would highly recommend the original type to all members. So they would be 50 bucks more big deal. Make them and they will sell themselves as soon as a couple of people use them.
Apiril 1976 DIRECT CONNECTION RACING MANUAL
Here, let me fix it for everyone so we can read it
Like your idea of making them to factory specs (blueprint) setting up masters to do it. Then they will have the factory base circles and use the stock length mopar pushrods.
The regrind cams to the 340 4spd specs are going to have smaller base circles and will need the push rod lengths looked into.
For someone who wants a blueprinted 340 4spd cam, your price is not that bad. Was about the same price as the last of the Mopar Performance 340 cams were costing when they used to be available at the end of their production. Now no longer available.
I personally don't get the problem. Oregon HAS the 4 speed cam on file and can grind it any time. I forget, I think it's either 1 or 2 degrees off on ONE spec. @krazykuda, Karl, I forget, what is it? It's dead on unless somebody wants to be a nitpickin rivet counter. You'll never see hear or feel the difference.
Reproduction 340-4 Speed Cam
W
Hello, by a stroke of luck and timing, I purchased an early removal 68 340 four speed cam from a retired Chrysler engineer who owned the cam since late 68/early 69. I also was able to get the original blueprint. I happen to be friends with the owner of Racer Brown Cams and we talked about making a run of these. We checked the cam on the cam doctor and it has been confirmed 100% authentic and almost all of the lobes have zero wear. I'm just curious about how many of you would legitimately say you would like one and follow through with payment. I will front the cost of making the masters so no up front cost to the buyers. Overall, the final cost for the cam (without lifters) would be $245 plus shipping. If you are interested and would be committed to buying, please reply below and add your name to the list. Thanks for your interest.[/QUOT
If you ever do it I would take at least one. But I do understand if you don’t because all the bs. For those of you talking about the other cams I’m sure they work fine and I’ve used many different brands myself but this one worked fantastic for me in street cars and never ran out of power even at 6500.
Wow!! When I saw the 68 cam specs i realize my cam is close to it. It was ground by a guy who used to work for Crane.
Adv duration and lift
Int .498 exh .512
Int. 274. Exh 286
113.5 LSA
In a 360 magnum, hydraulic roller
Stock block except for the cam/Springs, locks, retainers, air gap.
Did the stock 68 cam have a nice sound to it, nice lope at idle ?? What will more lift on mine do vs the 68 ?
Sweet spot for Mine is supposed to be 2000-6000. What is it for the 68 ?
BTW, this should settle any arguement
Brooks, I think you are refurring to Crane's "FIREBALL" cam. Just threw one away last year. Wish I knew they are no longer available, I would of hung on to it. Harvy Crane started in Hallandale, where I lived and most I knew were motorcycle racers. and very good at it. When Crane moved to Daytona most of his best grinders stayed in Hallandale.
Frank, thanks for all your efforts, I for one dont buy into the concept that close is good enough, i thought Oregon had the original exact blueprints for the 68 cam so thats what i was going to use, if you reach the 50-100 quota i would love to be a part of that, my build is right around the corner so time may be a factor,again thanks for all your efforts in trying to bring an exact copy of this cam to us 340 fans...Rich
@FWDLK Frank
How about picking up the ball again, looks like there is good interest here for the exact copies.
Nostalgic Engineering, those original engineers had steak and eggs for breakfast and could hardly wait to get to work and put in another day to work their magic .
They are not ONE of the best, they are THE best .... but only because MaMopar never installed a bigger or better cam, and as you know the 340 only ran from 68 to 73.
By today's standards, there are lots of better grinds; especially if you plan to run headers, and even more especially if you don't have the cylinder pressure to support these wide LSAs.
As to hydro versus solid;
Hydraulic lifters
present to the valve springs as very heavy, and the higher you rev then, inertially they just get heavier and heavier. Eventually the springs give up. At the other end; the ramps have to be Looooong to accelerate the heavy buggers without squeezing the oil out of them. And to set them down easy without bouncing.
So when you look at the Advertised spec, you might see 268 degrees.
But, firstly, this number is ethereal; in that some grinders measure this at .008 tappet rise while others at .006 , and others at whatever they want. There are no standards for advertised numbers.
So then, at .008 Tappet rise, the valve is still open, say .012inch with a true rocker arm ratio of 1.50.
What that means is that, your engine cannot make cylinder pressure until that .012 disappears to zero. And unless you know where zero is, this could be 10/14/18 degrees later. So then, seat to seat, of a 268* cam could be double the run-off room (say 14 x 2=28) plus the advertised 268 =296 degrees... or more.
Why do you care?
Because like said, your engine cannot start making pressure until the intake valve closes. In a short stroke engine, with a long-period cam, the EFFECTIVE Stroke computed from the closed position of the valve, can be very very short.
For a streeter this is bad because in order not to suffer a huge loss of bottom end power/torque, you have to increase the compression ratio to get the cylinder pressure up to a useful level. But to use today's gas, you can only go so far; Especially with iron heads.
Solid lifters, on the other hand are much lighter, and so ALL ramps can be faster and YOU, by setting the lash, determine EXACTLY when the intake valve actually closes, and by so doing, have exact control of the Effective Stroke.
However, because of the lash, you lose an amount of lift equal to the lash.
Furthermore, by adjusting the lash smaller or greater, you are also determining the advertised duration..... AND the 0.050 simultaneously.
This means that if you stick a 268 hydro cam into your engine and run it with solid lifters and lashed;you actually end up with a cam that is smaller than what you thought. Some say, about one size smaller.
This means, you gotta order a bigger solid cam to equal the smaller hydro cam.
The up-sides of this are;
1) Principally, that the lighter solid lifters will rev to a higher rpm with the same springs. and
2) the cam can be ground with faster acceleration rates, for more airflow potential at any given position, and
3) YOU have some control of the actual installed cam size by varying the lash.
The downsides are;
1) periodic lash adjustment, and
2) possibly a shorter cam life.
Now here is my opinion/ my experience; having run three hydraulic cams, namely; 270/276/292 intake degrees, in my Hi-compression 367;
IMO for a streeter, if you have the luxury of high cylinder pressure; just run a hydro.
But if you are stuck with a low-pressure engine, a solid lifter cam may, I say may, get you a tiny bit more all-round performance . If you go too big, you will suffer the same low-pressure/low-rpm problem, and the difference, typically,
is only one cam size.
And finally, you can get some pretty good results, by running a too-big hydro cam, and lashing it, lol. As we saw above, a 268 advertised cam might actually be 296* seat to seat. but if you lash it up, you might turn it into a true 268, seat to seat. You will lose both lift and .050 duration, but you will gain a bunch of cylinder pressure; perhaps as much as 1.5 psi per degree. If you give up 7 degrees of ramp, that calculates to 10psi, which could bring your pressure up from a mediocre 145 to say 155, hmmmmmmmmmmmm
This is of course trading away top-end power, to get bottom end power. But you can easily get that power back by resetting your valvelash to zero or less.
The downside to this is that the hydraulic lifters are now crashing into the non-existent clearance ramps, so into the acceleration ramps; and one would surmise this to shorten the life of the cam/lifters. Maybe, but I've been waiting since about 2006 for mine to give up......
Again, if you can get your cylinder pressure up to 155/160 with iron heads or 180/185 with alloy heads, in a streeter, IMO, you might as well stick with hydros. You can use your 273 gear with decent springs, to minimize the preload and thus rpm your engine to however high you dare; are you feeling lucky today? lol.
Happy NewYear !
Got me thinking, 340 E/stocker hydro cam but was or will use solids (at .002 lash) on it since were allowed to now. I’m stuck with stock lift but duration is out the door. Your opinion, should I get a new ‘solid’ cam or use what I have?
What do you use now?
Have no idea whose cam it is, got it in the package deal from a top Stocker guy. He said it might be Crane but it was fast. Haven’t run it yet, still trying to get car together.
What class are you going to run?
1971 Duster E/Stock auto 340. Was going the AVS 70 route but was talked out of that from another long time racer, AVS limited in rpm, TQ not
Interesting, do my specs sound like a Fireball ?
I have a bare 69 340 block and a pair of X heads.. my plan is a daily driver duster with a 727 and a 8.75 355 rear.. I think this 68 4-speed cam would make a fun driver.. just like they were in 1968!
That is 100% incorrect. All of the 340 cams were split duration cams. Had more than one 340 cam degreed and cam doctored and NONE of them were ever those lift specs.
My 2 cents it was written that way to sell more purple cams.
The 340 4 speed cam was the 340 auto exh lobe moved to intake side and a 440 mag int lobe set used for exhaust.
What A56 posted earlier in the thread is SPOT ON!!!!
Found this and it relates to the Service manual. This also shows the '68 340 automatic cam. Yep, I'm still looking.
*68 340 only
Automatic-equipped Barracudas employ a hydraulic cam with 268/276-degrees advertised duration and .429/.444-inch lift. With the four-speed, there's 276/284-degrees duration and .444/.453-inch lift. Both cams use shaft-mounted 1.50:1 rocker arms and connect to the crank via a double-roller timing chain.
There is PLENTY of incorrect info in the "Mopar" manuals over the years. Just because someone wrote it doesn't make it correct.
@Brooks James
The service manual for one.
I guess my own experience with these engines and building them over 45 years, nah I didn't write a book. Just know with my own eyes, tools and measuring devices what is right in this case.
Hearsay wont work. Lets see something in writing.
@Brooks James
Hearsay is inadmissable, as well as polygraph results , in court. Lets see some hard evidence.
I don't think he will share.
He's already got one MOPAR source for the correct specs that he can look up himself.
That performance manual is DEAD WRONG. But because someone wrote it it must be fact. Plenty of documents throughout history have misinformation in them that the masses take as facts.
A56 posted the correct and an incorrect set of values in this thread BOTH from MOPAR sources... at least the Race manual has the correct part number, but, they changed the grind from the originals.
