[Found!] Wanted Small Block Hydraulic Roller Camshaft
Jim Ward
Rockford MI
I’m in need of a hydraulic roller camshaft and will consider new or used. Preferred lift between 525 and 550. Send me what you have and I’ll check compatibility. In Michigan. I have lifters already.
thanks Jim
thanks Jim
What gears and what torque convertor?
I have a magnum rt cam.
3.91 with a 3000-3200 stall. Mopar 340 build.
CEH2 240/240 DUR@.050, 570/570, 110LC, 2500-6500
What heads? If the heads arent working in that range...just call and ask for .030 less lift.
Herbert Cams has just what I needed and it will be ground this week! Thanks for your help!
