[SOLD] Saturday Nite Parts Cleanout
RAT ROD AL
MOPAR ARCHAEOLOGIST - one parts hoard at a time!
Homeless
I have some more parts to clear out . Everyone should know the routine by now !
Claim parts by # listed. will combine shipping . Prices + shipping from Fl. 33956. Paypal F&F or you pay the fees. Thanks for looking !
#1
one 1" spacer sold... KrzyKuda.
1" & 2.5" sold...Dicer
$5 each 3-1" & 1 -2.5"
#2
Both housings sold... Steve..
34 tooth gear ...sold....plymouth67..
speedo gears $25 each . Teeth count marked on card board ! $5 each for the housings
#3
...sold Garret..
$7. Not sure which Holley this fits so I put the measurement there.
#4
...sold...j-anderson...
S/B 727 tube $10
#5
...SOLD KKuda
from 67 drum brake car. $30 May fit more.
#6
....sold..if3333
Heater control cables for non AC. 67 A body $15 all move freely.
#7
....sold Steve...
Not sure what Mopar this is from. Missing nut for the chrome bezel. $15 Other than that in good shape.
#8
Power brake booster assy. $45. It will surely need to be gone through and freashened up !
#9.......sold RightyTighty........
This one is in nice shape. Guy said it came off his 71 Dart with front disc.. Not sure of the M/C bore... # on M/C is DP33A
$60
Scroll on down for more parts and please claim by # listed.
67-69 notch barracuda rear side panels. good condition . will need paint. $25 for the pair.
#11
....sold... Kevin...
$15 8 hole plate.
#12
certicard sold OMR
Fuel pump eccentric, 3 drippers & trans line holder...sold Troy
$5 each
#13
...SOLD Steve..
New Remflex SB header gaskets. $20
#14
...SOLD... OMR..
4 and a half sets of SB header gaskets top pair looks like they were installed but not run. All others are new. $25 for the lot.
#15
318 oil pan gasket. $8
#16
Sold....
Massive lot of SB gaskets .. $50 for the lot
#17
lot of 2 440 valley pans with gaskets and 3 Valve cove gaskets All new. The metal trays have a light flash of rust from sitting around in an open box. $30 for all.
Thanks for looking Claim parts by # listed
Sign Me Up for #11 and I'll take the #16 Gasket Lot Also! (#11 I need the Gaskets for My Oil Adapter)
can anyone tell me what the starter shield in this lot is for ? And the small inspection cover ?
rt side oval type spacer is for starter. left side next to cooler line bracket is for older convertor cover. plate to inspect bolts without taking starter totally off.
slant 6 or v8 on the starter plate ?
could not find big cover in my parts cd but will look in reg parts book tomorrow. thinking they are same as they are just dust/rock shields. been too many beers ago. removing small cover allows person to drain convertor with out removing starter, braces, if equipped and shield. it takes a diff conv cover than normal.
