[Found!] Small Block 318 Camshaft retaining plate with bolts, and timing chain cover
Slantsix64
SSG
hey guys looking for the camshaft retaining plate with correct bolts and a timing chain cover what you got? timing chain cover year doesnt matter to me thanks!
I have what you need but timing covers vary from aluminum pump to cast iron pump Due to the lower hose on opposite side. $120 shipped for all parts cleaned and ready to install. Your choice of timing cover.
1-Timing cover.
1- thrust plate
4- bolts one with a hole for oiling
1- cam bolt and washer
1- fuel pump eccentric
1-Timing cover.
1- thrust plate
i have the early style 67-69 273 water pump
Tensioner is a bad move . They are a bandage for a cheap chain. Save your money and just buy a good billet tru-roller chain. It will out live the engine.
