TBI to carb swap
mopops
dutchess co ny
want to swap 81 Imp fuel injection to 2bbl carb. cant seem to get a 2bbl manifold ,so can i use my tbi manifold an a 2bbl carter carb ? what adapter would i need? i want to get all the parts before i disable the car in driveway tks
Can just re drill and tap your TBI manifold to the 2 bbl bolt pattern.
While you are at it you can easily go to a 4 bbl with the Mr Gasket carb adapter. Then you will have the advantage of the secondaries and can still run on the 2 bbls if you keep your foot out of it.
Advanceautoparts has them too.
i see no well for choke heater, another issue
Pop a 1406 Edelbrock on it (with the 2 to 4 bbl adapter) that comes with an electric choke. They run so much nicer, and they don't leak gas like the factory 2 bbls do.
Just like pictured here:
Video running on a 318 TBI intake:
