Slant Six Bumblebee
I just rebuilt my head of my slant six and upon starting there is no oil coming out of the rockershaft the engine has oil pressure I used the longer bolt in the back the notch is in front facing up
The shaft should also have the larger bottom of shaft hole at the back end where that longer bolt is. Hope they didn't clock the cam bearings wrongI just rebuilt my head of my slant six and upon starting there is no oil coming out of the rockershaft the engine has oil pressure I used the longer bolt in the back the notch is in front facing up
The rocker shaft is in right I think it was in backwards but I flipped it so the notch is facing forwards and upThe shaft should also have the larger bottom of shaft hole at the back end where that longer bolt is. Hope they didn't clock the cam bearings wrong
