Hold Down Pins 2 1/4 in Long ----Need Bendix P/N
mydart270
myDart270
Brattleboro, VT
Hi and Hello:
what is the Bendix p/n for hold down pins on a 9 in drum brake set-up. Some of my pins are slightly bent and I use Ebay as the price is right. Length is 2 1/4 in.
Thx....love MOPAR
None of the brake companies make a hold down pin that is exactly 2 1/4 inches long. Here are the pin lengths and part numbers that are close to 2 1/4. Part number h1106-2 1/8 inches, h1107- 2 3/16 inches and h1108- 2 5/16 inches. Go to eBay and put in the brand you want in front of the part number. For example Raybestos h1106 ,Bendix h1106, Carlson h1106. etc. Some of the companies pin lengths may vary by 1/64th to 1/32nds of an inch, not enough difference to be concerned about. For 9 inch drum brakes it's probably either h1106 or h1108.
Thank you so much. FAB forum members, you are the best!!
