I think they forgot the hardening!
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
I bought a jet screwdriver to remove some jets from a CARTER BBD carb (I have chewed up too many jets just using a wide screwdriver)
Looked good. Wide, flat, and textured. It's going to work great!
Put it on the jet and started to turn, a little resistance, ok no big deal.
Kept turning then it slipped, I figured the brass let go.
But no!
At least it was cheap!
Guess I should have asked if anyone can recommend one that works
Holley Jet Removal Tool, Black/Red
That was supposed to be a link to Amazon .?
That does look sturdier than the holley . But I have been using the Holley one since the 80s without fail . Does the Moroso one work on Eddie/Carter jets ?
I'm not certain. It makes no mention of it on Moroso's site.
I want to find a Holley air bleed tool. So far I have not.
Hold on, hold on...
I committed the ultimate sin...
It's a carter BBD with the tall jets.
I'm not sure if a Holly jet tool would fit.
I too was looking for the type with the blade inside a tube but no one states their id
Take a wide blade flat head and narrow it to fit the air bleed.
When I'd pull the metering block off I'd use a my keychain spark plug gapper.
But I usually leave it on unless the PV needs changed too.
Hold on, hold on...
What`s the diameter and length of jet?
I made a tool, I swore was for jets, found it and it seems really big. maybe for a thermoquad?
I dont have one loose right now.
Best guess is od 1/4 "
Height 1/2"
I know, but I would like a dedicated tool. Being the tool I am I like tools.
