nodemon FABO Gold Member FABO Gold Member Joined Mar 21, 2015 Messages 1,140 Reaction score 602 Location St.Louis Aug 14, 2022 #1 How are the cat whiskers removed / installed..? 72 Demon Thanks, John
Murray FABO Gold Member FABO Gold Member Joined Apr 19, 2010 Messages 3,809 Reaction score 3,088 Location San Jose, California Aug 14, 2022 #2 If yours are the same as mine (68), then there are clips built into the back of the strips that slip into a slot in the door. They form a "U" shape, so method for removal is a lifting and pulling away motion to remove it from the slot.
R Roadart FABO Gold Member FABO Gold Member Joined Jun 18, 2018 Messages 363 Reaction score 138 Location Escalon ca. Aug 14, 2022 #3 When installing the new ones DO NOT USE a steel hammer to help guide them in. Use rubber ,plastic something soft.
Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 14,961 Reaction score 12,317 Location Northern Colorado Aug 14, 2022 #4 Roadart said: When installing the new ones DO NOT USE a steel hammer to help guide them in. Use rubber ,plastic something soft Click to expand... Shouldn't need any persuasion but the palm of your hand
