e50095 Well-Known Member Joined Jan 27, 2010 Messages 216 Reaction score 47 Sep 30, 2022 #1 Can anyone tell me if the driveshaft is the same length whether you are using an 8 1/4 or 8 3/4 rear axle. If not, what's the difference in measurement? Thanks.....
Professor Fate Push the button, Max... Joined Jan 13, 2020 Messages 6,557 Reaction score 11,481 Location Wisconsin Sep 30, 2022 #2 Should be the same.
e50095 Well-Known Member Joined Jan 27, 2010 Messages 216 Reaction score 47 Sep 30, 2022 #3 Professor Fate said: Should be the same. Click to expand... thanks brother....
Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 14,935 Reaction score 12,297 Location Northern Colorado Sep 30, 2022 #4 Measure twice cut once. The parts books have dimensions based on car, rear and transmission But the best thing to do is get it installed and setting on it's tires and measure. Then if the factory books agree you're golden.
4 413 Well-Known Member Joined Nov 13, 2019 Messages 1,186 Reaction score 2,016 Location NW USA Sep 30, 2022 #5 Not the same. Axle centerline to center of yoke is: 8 1/4 11.70” 8 3/4 12.35” so the driveshaft is .65“ different.
