vallianted
hey all.wondering what size of exhaust i can run in my car just off of manifolds.
Jusy curios if the body size of the muffler interfered with your e brake cable?
Sorry but yes I am putting an 8 in my car.Are we to assume since you used "manifoldS", plural, that you have a V8? We're not mind readers, so maybe a little more info if you want an accurate answer?
Are we supposed to "just know" which manifolds you're using? Casting numbers and pictures will help. It's like pulling teeth.Sorry but yes I am putting an 8 in my car.
your the expert, you should know the correct answer,Are we supposed to "just know" which manifolds you're using? Casting numbers and pictures will help. It's like pulling teeth.
Hey bud, if I knew I wouldn't have asked. Never claimed to be an expert.your the expert, you should know the correct answer,
love this forum, so many "experts" who clearly know ..............zero!
Sorry if I caused any confusion here but I thought my question was quite clear and Darter6 seemed to be the only one who understood it .next time I'll be more precise for all to understand.Guys like Rusty/Rob are often willing to go to great lengths to help members here. He has helped me more than once.
What does NOT help is members that jump in asking for help while doling out little bits of information ONLY when asked.
What the heck, man?? Do you WANT help or are you just trying to be annoying?
People on these forums are often very generous with their time so stop wasting it by being stingy with the pertinent information.
Hey darter meant to ask you if I need to use the oil filter adjuster on my car for more exhaust clearance?Usually 2'' head flange. I ran 2'' at the flange and expanded to a full 2 1/2'' to the back bumper.
This photo was with 273/318 TTI shorty headers and their full exhaust. Muffler shops can make what you need.
Tks for all the info.I appreciate it.With manifolds I'd say yes. I like to run a small late model filter.Also with the standard flat plate you can use a short/small filter
such as Wix 1535.STP 3614.Some don't like to run a small filter.I do because I change oil way more often.
It's up to you.
