[SOLD] Parting out 69 barracuda notchback slant 6 3 on the tree
How is this area? Pass. Side rear
hi i need the front light housing to core support adjusters and buckets (whole assembly) for both lights also brake pedal bolt and rod plus steering column (minus wheel) im in 91977 thanks
Do you Still I have the front brakes if so what's the bolt pattern
Is this car going to the crusher when finished parted?
If so I`d be interested in rear window left top and bottom sheetmetal sections,
Does it have power steering? need the fitting, right angle design that power steering hose from pump connects to box please? brass design..
A buddy is looking for the steering column, including all the three-on-the-tree stuff and linkages. Do you still have it?
I sold the column and pedals but I do have the linkages and all the rest of the manual transmission stuff all the way to the driveshaft.
